Question component starts burning when plugging battery
ceetje
22
Yesterday my computer suddenly got a black screen while the fans where still making sounds. I turned it off but it didn't go on again when I tried. I looked up what i should do and one of the things I could do was a power drain.
So I unplugged the battery, but now when i plug the battery in again there is a component that starts burning. The component that starts burning is PU401. It's a Lenovo L340-15IRH.
Anyone knows what I can do to prevent it from burning and make my computer work again?
From the research i have done that is a capacitor, which is not good.. Is the capacitor leaking or bulged out on the top?
it sort of doesn't matter what part is burning - that is never a good sign and something that will only get worse.
unless you are handy with a screwdriver and soldering iron, and you deem the laptop worthy, it's time to take it to the nearest Lenovo repairer.
what is the age, about 3-4 years? any chance it is under an extended warranty plan still?
