Ps4 controller removes sound
deto
23
I just bought a new ps4 controller to use on my pc, and when i connect it with usb, all audio cuts out. This didnt happen with the old ps4 controller, and i need help fixing the issue, cuse i would like sound while playing.
Update: ive found out the audio comes through the ps4 controller, so if i put my headset into my controller, i do get audio. BUT, i do not get mic. So is there any way to make it so it prioritizes the actual audio outputs rather than the controller?
