Problems with my laptop
Omar2002
22
Hello, I have been experiencing problems on my win 10 lenovo laptop after deleting appdata and temp for example the search bar is not working/data usage of wifi not showing in settings microsoft edge not opening and other simple apps like calculator.
I just CRTL+A and than Shift+del I deleted them because i needed some space the total of the temp files were 17gb
You probably removed some information and reference files that the programs required for them to work.
If you can do a restore using the windows restore to a date prior to you doing this.
