Problems with gaming/ Graphics Carrd
chrysstreet
33
27
So recently i opened a topic on this forum regarding my problem with bluescreens, i was having crashes and blackscreens and BSODs while gaming, it proved to be GPU-related, as not long after the topic was opened, my Sapphire HD 5850 died completely. I also got a lot of tips regarding HDD maintenance and security on that topic, it was closed when i bought myself a new Graphics Card. My old problem was solved, no more bluescreens.
So here is where a new problem starts, this new Graphics Card i bought is a XFX RX 560 4GB, a card i read a lot about, watched reviews, benchmarks, read owner's opinions, everything before eventually deciding to buy it.
But once it arrived and i finally installed it, eager to play my favorite games, now with better performance, i was thoroughly disappointed when i realized it was way worse than my old GPU.
In my favorite game, Skyrim, i used to get anywhere from 50~70fps while playing depending on the load, this is on max settings with everything on, it kept the fps stable too. With the new GPU, i get anywhere from 15 to 50fps, it varies wildly and stutters A LOT.
In GTAV i used to get a decent 50fps with medium settings on the old GPU, now i'm sitting on 30~40 with stutters and framedrops (sometimes it completely freezes for a couple of seconds)
Even CSGO, a game this card is marketed for, it performes way worse, i used to play at around 120~140fps, never less nor more, this was on high with filters on, now i get from 40~80 on very low with everything turned off.
At first i thought "I screwed up, this card is really bad, shouldn't have bought it", but then while researching my issues i realized this is not at all how it's supposed to perform, CSGO per example, i've yet to see a video where it performs badly, most sit at around 200fps while on Very High with filters in 1080p, and i can't get more than 60fps with everything on very low playing on a 1366x768 resolution. I tried cleaning the drivers and reinstalling them three times, didn't work, switched cables, didn't work, i even wiped my hard-drive and installed it in a completely clean installation of Windows, same thing.
The card seems to be okay too, at least looking at it trough AMD's tools, activity seems normal, clocks seem normal, everything seems normal.
So i am torn, is this GPU damaged, is it bottlenecked by some other component, or is some other component not working how it's supposed to?
Here's my system specs:
http://speccy.piriform.com/results/hZy2jJSNqTovjXn34kCSE27
Hi chrysstreet.
Have you installed the latest drivers for the AMD video card from AMD's website?
When you are playing a game and the low FPS is occurring, have you opened up task manager while the game is running to make sure that no other processes or background programs are causing your computer to have lower performance?
Yes, in fact i cleaned the old drivers both with AMD's tools and with DDU, tried both the regular and BETA drivers, no change.
I also wiped my hard drive clean after this, tried it on a clean installation of Windows, same problem.
Before i reinstalled Windows, i closed everything before trying to play, as i always do, so nothing was open except the game, and Radeon Settings (i tried with this closed too), after reinstalling Windows, it was just the system and the game running.
Memory usage looks OK, CPU usage is fine too.
One thing i have been noticing is that Windows is taking an awful lot to load, this was expected when i had my old installation of Windows (full of programs, things starting with it, and hadn't formatted in over a year), but when i reinstalled it, i expected this to stop as it always does, it didn't.
It also shows me a black screen with just the cursor before the logon screen, something that didn't happen before, i also get weird freezes while just using Windows Explorer or browsing the Internet
Another weird thing i noticed is the GPU usage seems to keep jumping around while playing, not keeping to 90~100% as my old one did, this one can be at 100%, 0% or any number in between, and it seems to happen at random. Memory and clock speeds stay stable as they should.
I also notice the worst of the stuttering and frame-drops happen in heavy-populated areas in-game (Skyrim), close to explosions or big concentrations of people (GTAV) and during firefights (CSGO). Skyrim's towns seem to be the worst at this, as looking from the gate towards the city can bring the FPS down to 10.
This is as much information as i can remember right now from my problem.
What boggles my mind is the fact that, before my old GPU died, it didn't have these problems, or maybe i didn't notice it's slow performance loss since i had it for so long, but there definitely wasn't having frame-drops, can't say the same about the stuttering, as it did happen in some games, but not in others, but this was for a LONG time, so i just assumed it couldn't handle those games as well.
I know for a fact this new GPU should perform WAY better than this, so i'm thinking either it is defective, or i got some other malfunctioning piece of Hardware, but since i don't know for sure, i can neither replace the GPU nor buy a replacement for the piece of hardware i might need. I'm also pretty sure it's not Software related, because as i said, i tried cleaning, reinstalling the drivers, even wiping the hard-drive and had no change.
Are you overclocking any components? Have you tried updating the motherboards BIOS to the latest version?
When you open other programs other than games, is the computer still slow when opening up other applications?
Lets make sure there is no corruption in the file system.
Click Start< type Command Prompt in the Start search box, right click on Command Prompt and click on Run as administrator. After the Command Prompt window opens, type chkdsk C: /r and hit enter. Type Y to confirm that you want to schedule a Check Disk to run on the next restart. After the Check Disk has been scheduled, close the Command Prompt window and reboot the computer to allow Check Disk to run.
No overclock, the BIOS is up-to-date (updated it while trying to solve this)
Yes the computer is slower and clunkier than it used to be, not only in games but during other things as well, lots of freezes occurring for no apparent reason.
Here is the log from the CHKDSK thing, took me about 2 hours to complete:
"Checking file system on C:
The type of the file system is NTFS.
A disk check has been scheduled.
Windows will now check the disk.
CHKDSK is verifying files (stage 1 of 5)...
378368 file records processed.
File verification completed.
767 large file records processed.
0 bad file records processed.
2 EA records processed.
61 reparse records processed.
CHKDSK is verifying indexes (stage 2 of 5)...
491218 index entries processed.
Index verification completed.
0 unindexed files scanned.
0 unindexed files recovered.
CHKDSK is verifying security descriptors (stage 3 of 5)...
378368 file SDs/SIDs processed.
Cleaning up 209 unused index entries from index $SII of file 0x9.
Cleaning up 209 unused index entries from index $SDH of file 0x9.
Cleaning up 209 unused security descriptors.
Security descriptor verification completed.
56426 data files processed.
CHKDSK is verifying Usn Journal...
33729208 USN bytes processed.
Usn Journal verification completed.
CHKDSK is verifying file data (stage 4 of 5)...
378352 files processed.
File data verification completed.
CHKDSK is verifying free space (stage 5 of 5)...
114663467 free clusters processed.
Free space verification is complete.
CHKDSK discovered free space marked as allocated in the
master file table (MFT) bitmap.
CHKDSK discovered free space marked as allocated in the volume bitmap.
Windows has made corrections to the file system.
629190863 KB total disk space.
169833160 KB in 320787 files.
206932 KB in 56427 indexes.
0 KB in bad sectors.
496899 KB in use by the system.
65536 KB occupied by the log file.
458653872 KB available on disk.
4096 bytes in each allocation unit.
157297715 total allocation units on disk.
114663468 allocation units available on disk.
Internal Info:
00 c6 05 00 89 c1 05 00 8b 57 0b 00 00 00 00 00 .........W......
09 01 00 00 3d 00 00 00 00 00 00 00 00 00 00 00 ....=...........
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Windows has finished checking your disk.
Please wait while your computer restarts."
Any update for us Chrysstreet? This thread will be closed if not replied to within 48hrs.
