Problem with Dualshock 4 on pc ! Help me please!
Vanish_gold16
5
24
Hello everyone! I bought a Dualshock. I connected it a week ago, everything works fine. Installed DS4Windows recently. When I downloaded it, changed some settings there, Dualshock no longer works .. It does not even connect to the phone. When connected to a PC, via a wire, it lights up in the desired color, but is not displayed. When connected to bluetooth, it simply does not see it, or writes: "Check the Pin-code and try again." Help me please! I will be very grateful
It seems no one has any advice, or the person who may has not yet logged on and seen this thread.
do you still need help?
Yes. But it already works for me through an excuse. I removed that program and driver. Can you help me please?
To what device are you connecting the DS4? You mention connecting the DS4 to a phone, afaik you can only connect a DS4 to one device, if you pair it with another it will lose pairing with the original device.
Is DS4Windows running? Before you turn on the DS4?
