Hi again!
So today I had another BSOD and WinDbg again showed the ntdl.dll as the cause.
In the last thread the advice was the following:
However, I did not yet do this as it is quite 'invasive' - it would require me to remove the GPU, the chipset heatsink and remove the seal from the second SSD heatsink of the MB.
I purchased this desktop secondhand and could perhaps use some tips (if possible) before proceeding. Do I need to clean the SSD after removing it from the first heatsink? Could I remove the SSD and plug in a temporary HDD for testing purposes?
Thanks in advcance, already received so much help here!
swap the SSD into the alternative M2 slot and test by using the computer as you normally would.
