Hello,
I hope someone can help... I bought a new Seagate Expansion hard drive with 8GB capacity. I plugged it into the mains, and plugged its USB cable into my desktop computer's USB port. When I started the computer, everything booted up normally, and I could see that the new Seagate HD was recognised and was working fine. In Windows Explorer, I could copy, paste and delete files normally.
The file transfer rate for copying files onto the Seagate Hard Drive (USB v.30) was about 70MB/S. I thought that was a bit slow, as the Seagate was plugged into the motherboard's USB port that was USB 3.0, so I was expecting a faster date transfer speed.
After doing some research online, I learned that you can improve the data transfer speed by changing a Policy setting in the Device Manager, for the Seagate external hard drive. By default, the removal policy was set to the "Quick removal (default)" setting. From what I had read, changing the policy setting to "Better performance", and then in the sub-category, putting a tick in the option that says, "Enable write caching on the device", can improve the drive's data transfer speed, so that's what I did. A dialogue box popped up telling me I needed to reboot the computer for the change to take effect, so I clicked "Yes".
When the computer switched off, it automatically tried to reboot, but immediately the booting-up process froze, and nothing happened. If I turn off the computer, and unplug the Seagate external hard drive's USB cable, the computer boots up perfectly, and once I'm into the operating system (Windows 7), all is good. When I then plug the Seagate external hard drive's USB cable into the computer's USB port, again all is good, and I can see the drive in Windows Explorer, and I can copy, paste and delete files. Everything is normal.
If I turn off the computer and reboot with the Seagate external hard drive's USB cable still plugged in, the booting-up process freezes again on the first splash screen.
So basically, I can use the Seagate external Hard Drive normally, but only if I plug it in after the computer has fully booted up. I thought something might have happened to the external Hard Drive after I changed its setting in the Device Manager, so I took it back to the shop where I bought it from, and they exchanged it for a new hard drive... same make and specifications as the original... but the new replacement drive also causes the computer to freeze on start-up. The computer freezes too early to be able to access the bios, but I can access the bios if I unplug the external hard Drive's USB cable.
What could the problem be, please?
Thank you!
Specifications:
Computer type: PC/Desktop
Motherboard: Asus P8Z68-V PRO-GEN3
OS: Windows 7
CPU: Intel Core i&-2700K
Memory: 16 GB
Graphics Card(s): Asus Nvidia GeForce GTX 760 DirectCU II OC 2GB GDDR5
Hard Drives: SSD, OCZ, 240GB, Vertex 3 (boot drive)
Thank you!
Specifications:
OS: Windows 7
Memory: 16 GB
