So i start up my pc to fast realize that i have no sound on my pc. I check whats wrong and see that realtek is no where to be found. I go into devicemanager and look on some turtorials online on how to fix it. First realtek didint show up in sound list i had to turn on "show hidden" to find it. I see it and uninstall it as the the turtorial said. I tried restarting my pc to see if it would reinstall itself. it did not. So i tried using the option in device manager to let me reinstall older versions of a driver and i reinstalled the realtek driver. But this time it had an error sign next to it, it was code 10. I downloaded a program that updates drivers for you. And as the program was updating my driver my pc bluescreened and went into a bluescreenloop.
I decieded it was best if i completely reformated my pc so it might fix the problem. It did not, this time i tried downloading realtekdriver from my motherboard manufacturer. I did as informed and installed the driver and restarted my pc. When pc came problem was still not fixed. I tried reinstalling an older version of realtek in device manager again. But this time the pc bluescreened but it did not go into a loop only bluescreened once.
Also under systemdevices on devicemanger a driver called "high definition audio controller" also has a error sign next to it and it is also a code 10
Please i seriously need help with this.
Mod Edit: there are two of the high definition audio controllers, one with the error and one without, idk if theres supposed to be two of them or not maybe thats a error aswell?
Malnutrition.
Malnutrition.
