Solved Prevent need to reset network sharing to PS3
TrantaLocked
22
I use a PCIe wifi adapter for internet in my desktop PC with Windows 10. I want to share the internet connection from the wifi adapter to my ethernet port which goes to a PS3, and this works the first time I set up internet sharing.
However, after I restart my computer and PS3, sharing stops working and I must disable and re enable sharing, and disable and re enable both the ethernet controller and the wifi adapter. This means I cannot rely on the internet sharing over ethernet working every time I want to use my PS3.
How can I solve this?
