Solved Power issue with newly built PC (SPECS provided)
Mark__M
6
29
ISSUE:
Hello, I recently (1 week ago exactly) built a PC for personal and gaming use (specs listed below). Seemingly at random the PC will lose its display and stop providing power to the mouse and keyboard, which are connected by USB. However, the case fans, the power supply fan, and the cooling fan all keep operating in this state, as well as the light indicating the PC is on. Pushing the power button (both long and short push) does not cause anything to happen. The only way to get the PC operational again is to unplug it or turn off the power supply. After I restore power everything returns to normal with the computer starting up without any indication of error (no notification to start in safe mode or the like).
I do not believe it is a cooling issue as the fan that came with the Ryzen is stated to have thermal paste pre-applied and none of the PC’s components are hot or warm to the touch. I am not overclocking the computer.
SPECS:
I built the PC according to the video linked here (youtube PC build guide)
Parts list
AMD Ryzen 5 5600G
GIGABYTE B550M DS3H AM4 AMD B550 Micro-ATX Motherboard
Team T-FORCE DARK Za 16GB 288-Pin DDR4 SDRAM DDR4 3600
Western Digital WD Blue SN550 NVMe M.2 2280 500GB PCI-Express 3.0 x4 3D NAND Internal Solid State Drive
EVGA 650 BQ 110-BQ-0650-V1 80+ BRONZE 650W
DIYPC Gamemax-III-ARGB
Running windows 10 pro
Thanks to anyone for your help, if there is any additional info required please let me know
Your issue could be the psu, To be gaming you should have a gold standard psu with at least a 5 to 10 year warranty.
Let's get more help... @phillpower2
Thanks, is it common for a psu to fail in such a selective way (i.e the cord connecting to the motherboard failing while the case power is maintained)?
A PSU has different rails and it is possible for one to be bad and the others ok.
Thanks, the snapshot is here
I noticed some more specific causes of the issue. As a test I left my PC on, in idle on desktop for 2 hours without issue. I also was able to voice chat and watch videos with some friends for two additional hours without issue. However, when I started playing a game, the PC had the shutdown issue within 40 minutes, which seems to suggest it is some kind of issue with the game putting strain on one of the PC components.
Three things of note in Speccy;
RAM
16.0GB Dual-Channel Unknown @ 1796MHz (18-22-22-42)
The RAM is being overclocked past what the CPU can handle which as stated by AMD here is 3200MHz.
You need to disable XMP in the BIOS and then manually set the RAM to run at 3200MHz.
Graphics
SE2717H/HX (1920x1080@59Hz)
512MB ATI AMD Radeon Graphics (Gigabyte)
Onboard graphics is poor when it comes to gaming and especially when only 512MB of memory is available, this causes overheating and the PC running out of resources when you try playing games that the PC does not meet the minimum specs.
What games have you been trying to play.
Operating System
Windows 10 Pro 64-bit
Computer type: Desktop
Installation Date: 12/7/2021
Once Windows had been installed did you then install the chipset drivers for the MB, why this is important is explained below;
Once Windows has been clean installed you must then install first the chipset drivers, then the storage/SATA drivers and third the graphics drivers, the drivers can either come from a disk provided by the motherboard manufacturer or downloaded from the site and saved to a flash drive etc, this is a must and Windows should not be allowed to check for updates before it has been done as more often than not Windows installs the wrong drivers or in the incorrect order and this can cause all sorts of problems.
Thank you for the precise advice, I really appreciate it.
I was able to go into bios and disable the xmp and then set my ram to 3200
The specific game I have been playing is Warhammer 40k: Mechanicus. The settings recommended to run the game are as follows:
  • RECOMMENDED:
    • Requires a 64-bit processor and operating system
    • OS: 64-bit Windows 7, 64-bit Windows 8 (8.1) or 64-bit Windows 10
    • Processor: 3GHz Quad Core
    • Memory: 8 GB RAM
    • Graphics: 4GB AMD Radeon R9 380, 4GB NVIDIA GeForce GTX 960 or better
    • Storage: 11 GB available space
    • Sound Card: DirectX compatible sound card
After installing windows I installed the chipset. I believe windows updated after this as when I was installing windows initiailly my PC was not connected to the internet, after getting it connected I installed all the chip drivers.
If it helps I have attached an updated speccy here.
Once again thank you for your help. It is a great relief to have your assistance
Here are the listed minimum system requirements:
  • CPU: Intel Core i3 with minimum 3.30 GHz (if the GHz is lower than 3.30 12 GB RAM is required)
  • CPU SPEED: Info
  • RAM: 8 GB
  • VIDEO CARD: 2GB ATI Radeon HD 7970, 2GB NVIDIA GeForce GTX 770 or better
  • PIXEL SHADER: 5.0
  • VERTEX SHADER: 5.0
  • SOUND CARD: DirectX compatible sound card
  • FREE DISK SPACE: 8 GB
  • DEDICATED VIDEO RAM: 2048 MB
Thanks for the update/additional info (y)
You not having either of the above means that what was explained in my reply # 6 will happen;
You are welcome btw :)
Okay, after making the changes everything seems to be doing well. My computer no longer has the shutdown issue and I was able to play Mechanicus for about 2 hours with no issue. As @phillpower2 said it seems the issue is my hardware not being up to snuff.
I suppose my issue can count as resolved now, and it seems Speccy has some sort of temperature monitoring portion that I can use to make sure my computer doesn't overheat when I game anymore.
Thanks to everyone for their help, I really appreciate it.
Thanks for the update which we are pleased to see is positive news (y)
The RAM being OCd past what the CPU can handle would also be affecting the CPUs graphics capability and by setting the RAM to run at 3200MHz the CPU and its graphics have the required time to process the data and signal etc.
You are welcome :)
