Solved POST issues
lukas58
33
Hi Guys,
It would be a little complicated to explain so i recorded the problem, I hope you don't mind. Here is the link -->
The problem started a couple days ago when suddenly out of the blue windows 10 (pro) suggested me to update my windows to whatever new version because my version is coming to an end. So I installed the new build (18363) and the issue occured right after the 1st reset during the process. Since then I have returned to the earlier version of windows but the problem stayed, so I decided to put the new version back. Then, I tried to switch from my GPU to the MOBO's GPU in BIOS. That did not help either, nothing showed up before the windows loading screen. After that I removed the battery and popped it back in to reset the BIOS. I have checked the cables, removed the GPU, cleaned it then put it back. The problem is persistent.
Do you guys have any idea what could it be?
I am freaking out that it has something to do with my GPU but everything else works fine, just like before.. Also could it really be just a coincidence that the problem started with the win update...?
Welcome to PCHF lukas58.
Could you clarify something for us, by the above do you mean that you have that strange issue with the BIOS screen but then Windows boots up without any issue and all hardware works fine.
Well as much as I can tell, yes.
I had no other issue whatsoever, it runs AC Odyssey just fine. So I really don't know. Yesterday I did a RAM test, no problem was found there either.
Thanks for clearing that up (y)
The issue is pre Windows and therefore BIOS related and nothing to do with any Windows update.
If the computer works as it should I would be tempted to leave well alone, if you start tinkering with the BIOS something could 100% break and leave you with a dead MB.
