do you see the picture now?Hello
What did you use to try posting a pic?
thanks so much but how do i clean itOk it finally came thru, you want to have your thermal paste as thin as credit card maybe a bit thinner..Make sure you clean off the old paste first,which looks like you did.. If any paste oozes out wipe that up and remember not to over tighten those heat sink and fan screws.
okay thanks yeah i have problems its my firs ever build so we bougth r5 1500x processor and it had the thermal paste with it and when we turn the computer on it give 4 beeps and we think this is the problem (sorry my english)Were you have heating issues? It looked ok from the pic.. But if you want to replace the paste use some rubbing alcohol with some soft tissue or paper towel ..Do not use an excessive amount of alcohol. Buy some good paste like Arctic thermal paste and apply like instructed.
uum like the case or the mother boardHi. 4 Beeps error vary with different brands of PC.
What brand of computer?
its a custom buildHi. 4 Beeps error vary with different brands of PC.
Asus PRIME B350-PLUS, ATX thats my motherboardHi. 4 Beeps error vary with different brands of PC.
i have 2 ram sticks 4gbx2 8 hyper xHello folks,
How many sticks of RAM do you have
The details for cleaning off and applying thermal compound atop of a Ryzen CPU can be found here
i mean its vga or fairule of a component an i think its failure but i dont know what is failing
