please give me a fix for my bluetooth
deadlyaura
21
my bluetooth driver is not getting installed in my laptop even after i reinstall it and if it appers it is always in hidden devices tab in device manager
What is the product/model name of the usb device. Since you can find it in your device manager, go there and un-install and then re-start laptop to install the driver again and see if that works.. Make sure the transmitter bud is plugged in or if it is built in the mobo no worries.
I have tried it, but it didn't work even worse my Bluetooth is not working because of this error. I have tried many methods but all temporary it again starts doing same thing again.
If your Bluetooth is disabled then do the following to enable it.
Uninstall the device from device manager and restart Bluetooth service.
Start > services.msc
Right-click "Bluetooth Support Service."
Choose Automatic.
Go to device manager and right-click on your computer name and click "Scan for hardware changes"
Install the Bluetooth device drivers from the manufacturer's website, if any.
If the device isn’t showing under device manager or under show hidden devices then shutdown the pc, unplug the power cable & then reconnect, then go to device manager & see if there’s any unknown devices showing, if so uninstall this & then scan for hardware changes & hopefully Bluetooth will reappear.
I hope this helps.
First try what is posted above. If that fails then see below.
1. Uninstall your existing bluetooth stack (driver software that came with the bluetooth adapter).
2. Reboot your computer and click "Cancel" when Windows asks for the driver.
3. Run BluetoothDriverInstaller.exe and follow instructions of the wizard.
Download and install the BluetoothDriverInstaller_x64.exe this tool will usually find a decent generic blue tooth driver for your machine.
Reactions: veeg
