pc wont display anything
Post the complete system specs including make model and version
Including the power supply unit
What sounds beeps if any pattern do you hear
Is the screen connected to the display card or the motherboard
i just recently built my first gaming pc and everything turns on fine but it wont display anything on my monitor can anyone help me fix this?
You obviously have something going on with your graphics card. Make sure it is plugged into your mother board all the way. Make sure the pieces power cable from your power supply is plugged into the graphics card. Check your connections to the monitor. Did you re install the same hard drive or a new one.?? Makes a big differance.
