Pc startup issues
Sky Eagle
Hey, so I came bacm after 2 weeks abroad and we just installed solar power. I tried to turn on my pc, it turns on however nothing is transmitted to the screen, the screen turns on but doesn't show anything, ALSO the mouse and keyboard doesn't turn on. What should I do?
after two weeks away, the PC may have accumulated dust, or contacts may have oxidised, or even rodents may have taken a toilet break inside the case. :)
pull off the side cover (will assume it's a desktop) and pull out the memory sticks and graphics card (if one) and with a soft bristled brush, with the circuit board, the contact points and the motherboard slots they go in.
reseat the components and see how you go.
