PC restarts while loading performance heavy games? Please Help!
billmbay
22
Last year I build my first PC. It contains a ROG Strix B550-F motherboard, an AMD RX 6700-XT gpu, an AMD Ryzen 7 5700X cpu, 16 GB DDR4 RAM, 1TB SSD, and a Thermaltake Toughpower GX2 700W psu.
Whenever I try loading performance heavy games such as COD Cold War or Apex, my PC will restart almost immediately or shortly after loading the game. Otherwise, my PC runs smoothly. Temps seem adequate, as there are plenty of fans in the case. I’m thinking there is faulty hardware, or I need a larger psu. I’m not very knowledgeable with PC’s, so any help diagnosing this issue is appreciated. I can add more info if needed, thanks!
I should also mention I’ve run hardware performance tests with no issues.
A better PSU for sure, Thermaltake are not the best and this particular model gets a lot of bad reviews on Amazon.
Let's check for anything else;
List Installed Programs
List Devices (Only Problems)
Click on Go.
Being that the OP has revisited the forum but chose not to reply this thread will be closed.
