hi i recently built this computer in september, all brand new parts and never had any issues until about a month ago, my pc will restart itself when idle for 10-15 mins, it just cuts to a black screen, then it shows the motherboard launch screen, loads and is back to normal. sometimes it will load and need to "fix" the C drive after it gets restarted on the motherboard launch screen. It doesnt restart if there is a youtube video playing or a video game open, though it will restart if spotify is playing. I tried to stress test my pc using prime95 and it restarted itself about 15 mins into the stress test.
I believe i overclocked my pc right before this issue started happening, though i have since reset all my bios settings to default. ive tried disabling the c6, c7 states as well as changing the power supply control idle to typical current idle. Ive also tried launching it in secure boot, all my bios and drivers are up to date. Nothing has helped or made a difference.
The attatched image is a screenshot of my reliability history, you can see it started happening on jan 26th. clearly that is not normal or good at all lol, please help!!!!
Pc Specs:
CPU: AMD Ryzen 5 7600 6-Core Processor 3.80 GHz
GPU: AMD Radeon RX 7700 XT
Mobo: b650 eagle ax
RAM: 4800 mt/s 2 x 16
PSU: corsair RM750e 750 W 80+
Hard Drive: Patriot P400 Lite 2 TB M.2-2280
Pc Specs:
Mobo: b650 eagle ax
