PC restarting again & again
rckrocks
33
i checked PSU voltage but there aren't any problem without connecting to mother board PSU working perfectly but after connecting it restarting again & again system fan trying to rotate & then restarting what is the problem
Please go HERE and download the portable version of Speccy. Save it to somewhere you can find, locate the file and as it comes as a Zip file use your favorite unzip application to decompress it. Open the newly created folder and double left click Speccy.exe if you have a 32 bit system or Speccy64.exe if yours is 64bit. If you are not sure what your system is click HERE. This guide compiled by Gus.
Ow85
Speccy will open and after a short wait will display a summary of your system specs.
  1. Click on the file menu.
  2. Then click Publish snapshot.
fVjw
A dialogue box will ask you to confirm, select yes.
9dYl
Another dialogue box will open
  1. Click Copy to Clipboard.
  2. Then click Close.
Mynz
Now that your link has been copied please paste it into your next post. It should look something like the example below:)
http://speccy.piriform.com/results/6waAHapcLrZIVPakgxXXXXXXX
BTW: once you have finished with speccy and no longer want it removing it is easy because it is a portable app with no install. Simply delete the downloaded file and folder you created when you decompressed it. Gone:thumbsup:
