Pc randomly restarts (Asus anti surge)
Democraz
24
Hey I got a problem here
So the problem isn't really about building a PC but more of troubleshooting
Around a couplt months ago my PC randomly restarts itself (the power, lights fans goes out too) so I did some cleaning in hopes of getting dusts out, doesn't work, new thermal paste both on the CPU and GPU, nothing happens finally I got what the problem was, took my graphics card out and everything went fine
But then just last week the same problem has been happening very frequently (around 5-6 times a day)
Asus error messages says the "Asus anti surge" turned off the pc and I did some more digging then found out that it's a problem the power supply or the battery (it's a PC and there's this big battery box I forgot what it's called) but then I also found out that turning off the anti surge in the BIOS can also Be a risk to frying your motherboards up
What should I do here
More info :
It usually happens when I open games for example modded Minecraft made it crash alot but sometimes it can run for hours even. Note that I have no graphics card installed Which I can see why but alot of the times it crashes upon startup and normal web browsing also
What do
You are asking for help with a computer but have told us zero about it :unsure:
Provide information about your computer, is it a custom build or brand name such as Dell or HP, if a brand name, provide the model name or series number (not serial) if a custom build post the brand and model name or number for the CPU, MB, the RAM (including the amount) and the PSU (power supply unit) providing these details will enable folk to better assist you.
