PC Overheating Despite AIO Appearing as Working
AsianGod160
22
My PC used to work fine a few months ago, but recently I moved and when I unpacked my setup, the desktop suddenly does not work properly.
It boots fine and loads up the home screen as it should except now it makes a loud noise which I am 90% sure is coming from the AIO CPU Block.
On top of this, the temperature also now continuously rises at idle until it eventually overheats and shuts down. I have a Corsair H100i RGB Platinum Series, purchased around 3.5 years ago.
If you want to know what it sounds like, here you go:
I looked through and could not find any pins or connectors out of place or sockets. Let me know though if there is any specific pin that is most likely the reason for the pump not working properly that I should double-check.
Can you Download and run and then post. https://www.ccleaner.com/speccy/download
To publish a Speccy profile to the Web:​
In Speccy, click File, and then click Publish Snapshot.​
Speccy publishes the profile and displays a second Publish Snapshot dialog box. You can open the URL in your default browser, copy it to the clipboard, or close the dialog box.
The last part of each URL is randomized, so only people you provide with the URL will be able to find your profile.
The information given in Speccy cannot be used by anyone to hack your system
Could you also include the power supply specs E.g Cooler Master 850W Gold V2 NOT E.g 850w
Being that the OP has revisited the forum but chose not to reply this thread will be closed.
