Pc over heating..heat tube v hot
Mstenna1
30
So guys my pc has recently started overheating and turns off after 5minutes of being on and i noticed on of the heat tubes going from the fan into the CPU is roasting hot any tips should i take the tube off if possible an try clean it? Im a complete noob but my oc is a 2080 graphics and a great cpu so i dont want to replace pc as i didnt buy it long enough ago
What tubes are you taking about?
Where and can you post a picture to show?
Have you tried using compressed air to clear the dust out of the system and fans? Using caution not let the fans spin when the air hit them will ruin them.
