Solved PC not displaying to monitor
MisterMR
3
33
Hi,
Anyone that can help me with this issue, i appreciate. So the situation is that i moved to a new place and now when i set up my PC again the displays are not working. I tried different monitors with HDMI and DVI ports but just no signals. Originally I built this PC and it has worked well for 2+ years.
Also, when it boots up it beeps and sounds like it is going through the normal boot up process.
Any help or feedback would be appreciated.
If you have moved your PC the first thing to try is reseating your add in cards and ensuring all your internal electrical connectors are secure. Also if you have a dedicated graphics card ensure your monitor is connected to it and not the onboard connector.
Reactions: MisterMR
Actually i figured it out... I had plugged monitors into mobo and not gfx. But thx for reply. :)
Reactions: veeg
