PC is randomly crashing(without a blue screen just shutting down) but the components will stay on and fan speed increases.
You have a decent CPU that is capable of high end gaming, suggest that you physically remove the 4070Ti from the PCI-E slot on the MB and hook your screen up to the appropriate video port on the MB and then test the PC by using it as you normally would.
Two things to mention, adding more screens and having the Windows Power Plan set to High or Ultra Performance both cause higher temperatures than normal so when trouble shooting both of these need checking.
