I’ve been at this for a few months now and I just can’t fix or find how to do this.
So a little run down. I wanted to do a fresh reinstall of windows 10 so I flashed everything just so I don’t have any viruses or whatever from my previous stuff. After I did that I got to install the windows 10 from my usb media and It’s installing then it would hit 95% and let’s be something is wrong. so my brothers pc is build the same as mine but with a different gpu so I installed windows on his pc and it works. Now I installed the hard drive back on to my pc and it works but really weird, sometime i’ll be downloading things and it’s corrupted or broken files. It blue screens if there is to much stuff going on, google chrome crashs if more then 10 tabs are open, I can update anything.
This is the lasted code i got 0xc000021a and it keeps going into a boot and crash so i don’t know what to do. I have no idea what it could be but everything is really off or weird on this computer now.
I’ve replaced almost everything on this pc
Parts list
amd 5 2600
rx570 8gb
16 gb ram 2133
600w vega BR
Asrock b450m pro4 5.30 bio
2Tb hard drive
Parts list
amd 5 2600
rx570 8gb
16 gb ram 2133
600w vega BR
2Tb hard drive
