PC Help!
dmuro99
25
I'm basically mentally 2 years old when it comes to understanding Pcs and how they work. This is a prebuilt Pc I bought off someone. The only thing I added to it was the SanDisk SSD storage. I want to definitely upgrade my CPU since I want to play New World and it recommends I7 or higher. Literally, any help will be Amazing!
Operating System
Windows 10 Home 64-bit
CPU
Intel Core i5 3570K @ 3.40GHz 48 °C
Ivy Bridge 22nm Technology
RAM
16.0GB Dual-Channel DDR3 @ 799MHz (10-10-10-27)
Motherboard
ASRock Z77 Extreme4 (CPUSocket) 38 °C
Graphics
DELL S2422HG (1920x1080@59Hz)
Intel HD Graphics 4000 (ASRock)
4096MB ATI Radeon RX 580 Series (Unknown) 40 °C
CrossFire Disabled
Storage
111GB KINGSTON SV300S37A120G (SATA-2 (SSD)) 33 °C
476GB SanDisk SDSSDH3 512G (SATA (SSD)) 33 °C
Optical Drives
No optical disk drives detected
Audio
AMD High Definition Audio Device
according to their site; https://store.steampowered.com/app/1063730/New_World/
you currently meet the minimum specs.
have you tried running it with your machine as is and seeing how it performs before forking out for new components that may not be required?
I know it meets the minimum but I wanna hit at least the recommended I just don’t want to sacrifice any graphics or hit lag or anything. I’m hoping you guys can give me some parts you recommend I use to make it better
The one thing that we also need to know is the make and model of the current power supply that have have.
You might also want to answer the other forums that you have posted this on as well.
Like they have asked what is you budget that you are willing to spend.
Motherboard
CPU
RAM
Depending on the PSU that you have.
