pc has 3 beeps with pauses its goes beep beep beep (pause) beep beep beep and dont stop
Sorry but you have post on a tech forum asking for help but have provided zero information about your computer or it`s hardware, this makes it impossible for anyone to even hazard a guess as to what is going on.
Is the computer a custom build or brand name such as Dell or HP, if a brand name, provide the model name or series number (not serial) if a custom build post the brand and model name or number for the CPU, MB, the RAM (including the amount) add on video card if one is used and the PSU (power supply unit) providing these details will enable folk to better help you.
Lets get a speccy report.
Let's see if there are any error message that can be pulled by the MinitoolBox.
Download MiniToolBox and save the file to the Desktop. Right click on the file and select Run as Admin
Close the browser and run the tool, check the following options.
Select all
Click on Go.
copy and paste the contents of the file called MTB.txt or attach the file to your next post.
while we wait for the Speccy report (if you can boot the PC), or any specs really, the most common reason for 3 beeps at startup is memory or grpahics card not detected.
assuming it's a desktop PC, remove the side cover, take out the memory sticks and graphics card (if there is one).
clean all those circuit boards, their contact points, and their respective motherboard slots with a soft bristled brush.
reseat those components and see if that helps.
but yeah, knowing some specs of the system would help. :)
