so today i left my pc on to go do something and when i came back i tried to move my mouse and it wouldnt move and with a couple keyboard presses i realized nothing would work, so i figured i would restart my computer.
upon restarting my computer, my monitor would not display anything, my AIO fans would spin and the others wouldn't, my LEDs all came on, and i found that when i held my power button and realized even after 20 seconds it would not turn off so i ended up pulling the cord because i lost my last pc to my powersupply frying my setup (it was 6 years old and prebuilt.)
i went online and tried a few fixes, i swapped ram sticks having one in at a time, tried using iGPU, tried unplugging everything but my ram and gpu (all peripherals,) made sure all power connections on mother board were seated. im not sure if this helps but it seems my monitor can tell when my hdmi gets plugged in or unplugged to gpu
only had this build for 6 months. my last idea would be to try and maybe flash the bios but im inexperienced with bios issues so.
Specs:
MB: Asus ROG Strix B550-F Gaming WiFi II AMD AM4 (3rd Gen Ryzen) ATX Gaming Motherboard (PCIe 4.0,WiFi 6E, 2.5Gb LAN, BIOS Flashback, HDMI 2.1, Addressable Gen 2 RGB Header and Aura Sync)
CPU: AMD Ryzen 7 5800X - Ryzen 7 5000 Series Vermeer (Zen 3) 8-Core 3.8 GHz Socket AM4 105W None Integrated Graphics Desktop Processor - 100-100000063WOF
GPU: GIGABYTE Gaming OC GeForce RTX 3070 8GB GDDR6 PCI Express 4.0 ATX Video Card GV-N3070GAMING OC-8GD (rev. 2.0) (LHR)
SSD: SAMSUNG 980 PRO M.2 2280 2TB PCIe Gen 4.0 x4, NVMe 1.3c Samsung V-NAND Internal Solid State Drive (SSD) MZ-V8P2T0B/AM
AIO: CORSAIR CW-9060060-WW iCUE H150i RGB ELITE Liquid CPU Cooler
RAM: CORSAIR Vengeance RGB Pro 64GB (2 x 32GB) 288-Pin PC RAM DDR4 3200 (PC4 25600) Desktop Memory Model CMW64GX4M2E3200C16
Power Supply: CORSAIR RM850e Fully Modular Low-Noise ATX Power Supply - ATX 3.0 & PCIe 5.0 Compliant - 105°C-Rated Capacitors - 80 PLUS Gold Efficiency - Modern Standby Support
Specs:
