Windows 11 Pro Build - 22000.282
Processor AMD Ryzen 7 3700X 8-Core Processor 3.60 GHz
Installed RAM 32.0 GB = 2 x 16gb
System type 64-bit operating system, x64-based processor
GPU AMD 5700 XT
Power Supply: 600w 80 plus gold rgb
In task Manager there is a problem where alot of games or apps have a very high power usage problem. The pc used to crash but after updating the bios, it has been stable under cinebench, Heaven Benchmark and 3dmark time spy. I had a problem where when rendering from premier which is gone now as well.
My question is the problems initially started when I tried to overclock the ram or put it on its profile 1 on xmp or when I tried to overclock the cpu using ASUS smart software. Do I need to upgrade to 1000w Titaniam 80 to fix these very high task manager games/software and overclock problems?
GPU AMD 5700 XT
