Pc case
Egegul
24
Hello I have a cit flash pc case and they said every time I press reset button it should change fan colours but idk how to connect it
was the PC built for you, built it yourself?
did the RGB's used to work, never worked?
does the Reset button no longer actually reset the PC, that is, the front panel Reset button no longer connects to the motherboard front panel header and instead go es to some RGB fan controller?
