1-Partition Assistant -2nd Repair Sector sequence
BOOTSECT BOOTNXT bootmgr need to copy from xp {administrator permissions in xp}?
use {test disk}
Repaired 3 Sectors but fixed not quite ok {1- wrong ,2- sucedssful } then how to fix the 240 GB Sector
what first should be
delete the wrong Sector 78 to 240GB RAW and rescue data
or
adjust Cylinder first ??COULD "align" Partition MAKE IT FIX?
78Gb {80} I have never write anything yet
correct to 240 GB(80+160) Sector
2 --administrator errors BY XP+W10 dual OS interfere Hard disk management {failed connection and fail stat other hdd and Sectors}
DUO TO WRONG HDD connection {dual os booting by accient } in the same pc
how to take Highest authority back from win xp
supposed to win10 booting alone
MBR was Repaired
xp x86 and win 10 x64 both can be boot alone successful
