Solved Occasional offset images.
Cranfield
3
77
Sometimes, I get offset images when viewing visual novels on my PC.
Commonly, the top half of the image is offset from the bottom half , sometimes it is as bad as this example I have attached.
Any help in alleviating this would be appreciated.
Are you using an app, browser, program?
When does this happen?
This is the only place that it happens?
Thank you for the swift response.
I have been searching for a solution for some time, today I was successful.
It appears to be the Renderer.
The solution is, in gameplay press shift +G and select Force ANGLE2 Renderer , this returns the image to normal.
Reactions: veeg
