Solved Noise GPU; Help pls!
VikiFray
4
32
Hello everyone!
I just bought a new PC (specs below) and I found it rather noise. I bought it without SSD and HDD because I use my previous ones (non of them more than 2 years old) so no settings were made on it in the shop. Without any issues I install the SSD and HDD and reinstall the Windows but i didnt install any driver manually i let the Windows do it. So when I start the PC the GPU fans are loud even without running anything.
Can I do something with it? Or it is okay that has a higher base noise?
This is my first 'gamer' PC, my privious one was much more weaker and had almost no sound.
Can somebody help me?
Spec:
Gigabyte AB350M-DS3H
AMD Ryzen 5 3600 6x4,2GHz
nVidia GeForce RTX2060
2x8GB DDR4 RAM G-Skills
Chieftec 650W
SilentiumPC Spartan 3 PRO CPU Cooler
480 GB SSD (Kingston)
1TB HDD (Toshiba)
AIO Magnum house
Hello ,
GPU Buzzing noise in games?
Or does it generally make noise?
It can be coil whine from your Video Card .
Hi
Both but mostly in game. Its much louder there.
In general its okay, but still louder than my previous pc but i think its just because it has more fans and bigger capacity
Hi
I just listened some youtube video about coil whine (sorry im noob, i didnt know how sound a coil whine) but it doesnt that sound that mine made. Mine is rather sound like it spin very very fast, much faster than it neccessary.
The first thing to try would be to remove the driver windows installed for your graphics card and install a driver ONLY FROM the manufacturer of the card.
Good news and thanks for letting us know that all is now well with your computer (y)
