Solved No sound on laptop
So others can assist you
Have you made any software, hard ware changers to the system?
Include the make and model of the Power Supply Unit if this is a Desktop.
Hi, I do not have any sound on my HP 15 laptop. Only if I use an earphone then can I hear any sound.
There is zero wrong with your audio chip or drivers with the proof being that the earphone works.
Possible causes include you have muted the speakers or the speakers have either blown or become detached from the MB.
It would make things a whole lot easier if you answered the questions that were asked, it avoids suggestions being made that you may have already tried.
