No post no beep fan spinning
MissStep
3
1. Mobo - Gigabyte GA H110M S2 Intel H110M Chipset Motherboard
2. PSU - AVF Extreme Power 650W
3. CPU/Processor - i5 Intel Core
4. GPU - Asus GT730 FML2G
5. RAM - Avexir DDR4 8 GB
6. Hard disk - SSD Sandisk
The mobo and psu is newly replaced. All hardware works fine but no post no display.
1. I use vga cable then switch to hdmi cable. Result no display no post no beep. But when i check both cable connecting laptop to monitor, both ok.
2. I use vga cable on GPU then change to mobo vga connector, the result same thing, no display no post no beep.
3. I do noticed the mobo box comes with cd but i cannot install it since my pc not display anything.
Can anyone help my case?
I want to avoid technician in my area as they always suggest to just buy a new one..
While waiting for other to post.
Lets try this
1. make sure that you are plugging into the display card and not the onboard.
2. Remove the display card and connect to the onboard and see if you get anything.
What DDR4 ram is it make and model
Which exact version of i5 CPU is it that you have.
Wouldn`t trust the PSU as far as I could throw it, especially if it is the real old version that has a floppy disk drive connector.
The PSU and mobo is new . I bought the same model as before for compatibility
Lets try this
1. I have plug into gpu and then change to mobo. Same result no display. The vga and hdmi connector both i used. The connector is not faulty so the only left is mobo and gpu. All fans and all usb port working so mobo is ok i guess. The gpu fan works but when connected to monitor, no display.
