Solved No network fix
Frenchels
4
27
Hi everyone.
My PC has been giving me this issue for a while now where it connects to the internet but tells me I have no network.
I have internet access and most functions work fine without it but, as a result, I can't play certain games or do any Windows updates so I was hoping if anyone could help me to fix this?
If I hover the mouse over the ethernet icon in the bottom right it says "not connected - no connections available" but like I said, I do still have internet access.
Please help.
Welcome to PCHF Frenchels.
Could be a browser security plug in issue.
We can see a couple of problems in your Speccy report, you are running Windows 10 Version 1703 which means that you are missing 2+ years worth of updates and therefore at risk of malware attack and what could potentially be affecting your internet service McAfee WebAdvisor which is a security plug in that is complete garbage.
You can uninstall McAfee in the Control Panel but should you have any problems see McAfee product removal tool (MCPR) here Please create a new system restore point first.
Once you have gotten rid of all traces of McAfee you need to get Windows Defender up to date, allow Defender to carry out a full scan and then start getting Windows 10 fully up to date, post back when you are running version 1903, it will take you a while but no rush on our behalf.
Okay well I can uninstall McAfee but I can't do any windows updates because of the network error. That is why everything is so out of date. Is there a different way to do windows updates because if I try use the windows updater it fails.
Okay so I uninstalled McAfee and it still wouldn't do updates but what I ended up doing is I used the media creation tool 1903 and reinstalled windows and that seemed to fix the problem. thanks for all the help man :) I really appreciate it.
Windows is officially up to date again and the network problem is fixed as well.
Reactions: phillpower2
Glad you got it sorted, will mark solved. Should you need further assistance in the future with this please contact a staff member who may reopen it for you.
