I just got a new used motherboard 2 weeks ago MSI MEG B550 Unify-X. Since using this mobo I've had multiple instances where I lose display as in the screen goes black, I then get a 00 on my motherboards Debug LED readout. Pressing the case power button does nothing, the same with pressing the reset button on my case. I also have a power button and reset button on my motherboard and pressing them does nothing, my system stays on, with a black screen and my fans going at the normal speed, they aren't ramping up or anything. The only way to restart the system is to turn off the PSU then turn it back on and press the case power button and my system boots like nothing happened. I do not have a minidump file to share unfortunately. I checked Event viewer and all it shows is The previous system shutdown at ... on ... was unexpected. I've included the event viewer text attached to this post. I checked my system temps and all are in normal range including CPU and GPU. I went ahead and ran scandisk and there are no errors I also validated my Windows install and there are no errors with that. I thought maybe it was a BIOS issue so I went ahead and rolled back from the newest bios version to the 2nd newest bios version and it still happened.
Also i noticed in Event viewer that i am getting a lot of errors having to do with network and some software. If you guys have any programs you want me to run that will provide some more info I'd be happy to do that. I'm on the latest build and version of Windows 11 Pro, just clean installed last night.
More info: Since this is a redone thread I disabled PBO and CPB and increased DRAM voltage by .050 and it appears that may have fixed it although I'm not sure becuase this issue always just happened randomly. I ran it with PBO and CPB disabled for about a week and no issues, I just reenabled them but left the DRAM voltage increase, I've only been running it like that for about 3 days but so far no issues. I've looked online and it appears this has happened with other people and no one ever figured out the core cause of it, most threads having to do with this issue ended up dying with no resolution. The only one that seemed to be resolved was the one suggested the person disable PBO and CPB and increase DRAM voltage. Bottomline though is I'm not going to disable PBO and CPB. I have a high performance CPU that i just purchased last year on Cyber Monday and I refuse to run it underspecced.
Specs:
Mobo: MSI MEG B550 Unify-X
CPU: Ryzen 9 5900X
GPU: Asus TUF Gaming RTX 3080 10GB
Old RAM before I replaced it yesterday: Kingston Fury Renegade 64GB (2x32) DDR4 3600 C18
New RAM Just Installed yesterday: G.Skill Trident Z RGB 64GB (2x32) DDR4 3600 C18
PSU: Corsair RM850X
My PC is not a prebuilt or a OEM, I built it.
Speccy Report:
http://speccy.piriform.com/results/G68oJ35AWFglORpxWVOdl3k
Specs:
CPU: Ryzen 9 5900X
PSU: Corsair RM850X
Speccy Report:
