I just put together my first water-cooling build, and there is consistently bubbles appearing in the gpu block and cpu block, and a massive amount building in the reservoir. I checked to see where air might be getting in and there arnt any leaks. the gpu caps at 80c before crashing itself to not kill it and I cant even get close to 100 frames cause the gpu gets too hot. should I change the loop to only cool the cpu and use the stock cooler on the gpu or not give up and keep looking to see if I can fix this? any help is appreciated!
3dMark Time Spy
Water Loop
3dMark Time Spy
Water Loop
