Solved New pc build help please
allan hogg
70
34
Hi I currently have finished building my pc project and have made a pc
With following
Mobo - Gygabyte gaming za-z170 k3
Ram - corsair vengeance Ddr4 2x4gb
Graphics card - Msi geforce 1050 2gb
Power supply - evga 600b
Cpu - Intel core i3 6300 processor
1tb solid state hard drive
Anyway my setup seems to be unable to play bendy and the ink machine game on steam is this right
Should also say I have three missing drivers in my device manager will find out what exactly when It finishes installing and I haven't ran driver disc for graphics card as I don't have disc tray yet
Pc I data acquisition and signal processing controller pc I memory controller and sm bus controller all need drivers on device manager
Once you installed Windows you should have installed the drivers for the motherboard, unless these drivers are installed and starting with the chipset drivers first you will continue to get problems.
Your specs are way above what is required to play that game so any problem lays elsewhere.
What is the actual problem that you are having.
How are you connecting to the internet, wireless or Ethernet connection.
Are you actually able to connect to the internet.
Hi so sorry got it working now went on my device manager got part I'd and searched it then went to Intel site and downloaded chipset so got all drivers installed now me andmy child played bendy and it worked perfect thank u
Sounds good,glad you got it working. I will mark your thread as solved
That is great news and thank you for letting us know that all is now well with the computer (y)
Just a FYI, the later versions of Windows will often have generic drivers that will work with a lot of hardware but the one thing that Windows will not have drivers for is the chipset, a job well done on your behalf for having the right idea of downloading and installing your chipset drivers and resolving the issue in the process (y)
