*Specs of my PC are at bottom of thread*
Ever since I built PC I have had wireless connection issues. I move around a lot and am using different modem and routers but can never seem to get a strong wireless signal on my pc. It should be noted that my phone and apple laptop do not have the same issue using a wireless connection so I don't believe it has anything to do with the distance from modem/router or location of my pc. I have made sure to update all my drivers, restarted my network settings, and have done numerous tests to see what it is wrong but nothing comes up. My motherboard does not have wifi capabilities so I have plugged in a tp-link AC1300 Wireless Dual Band PCI Express Adapter (Archer T6E).
My Network profile is Private and I am not using a metered connection. Here are some of the properties of my network.
Security type: WPA2-Personal
Network Band: 5 Ghz
Link speed: 866/526
When clicking on my wifi2 status it shows
Ipv4 connectivity: Internet
IPv6 Connectivity: Internet
Speed: 585.0 Mbps
When Diagnosing it, no issues show up.
All three of my Firewall's are active and on. Chrome is my main search engine and it is allowed through the firewall. When running the "Internet Connections" troubleshooter, no problems show up.
I've had to deal with this poor connection for over two years and have spent hours trying to fix it. I ask for any suggestions and comments. Thanks in advance to anyone that tries to help.
PC Specs
Device name DESKTOP-SF7TFKL
Processor AMD Ryzen 5 1600 Six-Core Processor 3.20 GHz
Installed RAM 8.00 GB
Device ID F150B707-74C5-4360-ABEB-C44EB1341E9D
Product ID 00325-80784-76294-AAOEM
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Motherboard B450M Gaming Plus (MS- 7b87)
Network Band: 5 Ghz
Link speed: 866/526
Speed: 585.0 Mbps
PC Specs
