Need help with PSU and GPU
Milenko
10
23
Im buying a PC without gpu, and then gpu seperately. The PSU is 320W HP cfh0320ewwa, and it doesn't have 6 pin connector for gpu that I'm gonna buy, and that's Gigabyte Windforce GTX 1050 2gb GDDR5 OC. They said they'll include SATA Molex to 6pin, but I googled it and it sais it's very dangerous, but having 2 of those isn't. So should I get 2 molex to 6pin or I'll be fine with just that one? (gpu is using 75w)
recommended PSU for that card is 300w.
power supply is one component I don't skimp on, why get a cheap, under-powered PSU to protect an expensive rig?
go for something around the 700w range, and at least 80+ gold certified, and if the company doesn't back it up with at least a 5 year warranty, find another manufacturer.
Being that the OP has since visited the forum but chose not to update their thread this thread will now be closed.
