Need help with PCI!!
Colton
28
I picked up my pci adapter today and I've already attempted to download the drivers and when I restarted my computer it comes up saying "Entry point not found the procedure entry point apsSearchainterface could not be located in the dynamic link library
is it still booting to windows? by the error I'm guessing it's a PCI WiFi card? sounds like the wrong driver was installed.
if still boots install correct driver.
if not booting do a system restore to a time before the install of card.
then install correct driver.
what model is the PCI card?
