Solved Need help repairing a 0xc00000e9 error on W10
lusgi
4
36
Hello,
I've got a laptop on W10 that stopped booting recently with the 0xc00000e9 error. I've tried a number of things, including checking the SSD plugging, running cmd commands about bcd and such. The disk was seen using diskpart, chkdsk and sfc found nothing to repair. Using a live Ubuntu on an USB key, I was able to see the Windows disk and save all the important data. I then wanted to use a live Windows (on the same USB key) to try and repair or reinstall Windows, but I don't manage to do it.
I've made a W10 64b iso with the official MediaCreationTool and made my USB key bootable with Rufus (I've also made the USB bootable directly with MCT with the same results). I've tried every combinaison of Rufus and BIOS parameters but none seems to be working (see table bellow). Either I get a blank blue screen, either a scrambled screen with horizontal lines. Whenever I do get to the Windows installation part (only with the MBR type key), it says it can't repair Windows and neither can I make a new install of it because it says the drive is in GPT.
I've used both USB 2 and 3 slots on the laptop with the same results.
Is there another way to repair the 0xc00000e9 error ? Is there any option I'm missing to reinstall Windows on this laptop ? Would formating the disk let me install it afterwards ? Would installing Ubuntu over Windows allow me to install Windows back ?
Thanks very much for any help.
The table of tests :
Rufus optionsBIOS options
PartitionFormatDestinationCSM (Disabled/Enabled)Secure Boot (Disabled/Enabled)Fast Boot (Disabled/Enabled)PXE (Disabled/Enabled)UEFI keyObtained result
MBRNTFSBIOS (or UEFI-CSM)DDDxYBlank blue screen
DDExYBlank blue screen
DEDxYBlank blue screen
DEExYBlank blue screen
EDxDYScambled image
EDxDNGet to Windows repair but cannot install it
EDxEYScambled image
EDxENGet to Windows repair but cannot install it
MBRNTFSBIOS or UEFIDDDxYBlank blue screen
DEDxYSecure violation
DEExYSecure violation
EDxDYScambled image
EDxEYScambled image
GPTFAT32UEFI (no CSM)DDDxYBlank blue screen
EDxDYScambled image
EDxDNRufus error screen
EDxEYScambled image
EDxENRufus error screen
GPTNTFSUEFI (no CSM)DDDxYBlank blue screen
EDxDYScambled image
EDxEYScambled image
If you used the medial creation tool there is no reason to use Rufus the tool will create the USB drive and make if bootable.
I would suggest that you recreate the USB using the Media Creation tool from scratch and see if that helps
If you still get the same issue you can use the new USB to access DiskPart and delete the drive and then install windows.
Thanks for the reply !
I've already tried using the media creation tool alone with the same result but I'll give it another go.
Is this done with the "clean" command in diskpart ?
Thanks a lot, after doing the "clean all" I've been able to install Windows!
