Need Help Overclocking
noahnoda
11
25
Ive Been Trying to overclock my cpu for a while now its a R7 1800X on the site it said its max boost clock is 4.0 ghz {Base Clock Is 3.60} and max memory speed is 2667 mhz {base is like 2100} but anytime i go over the base amount my cpu is when my pc boots up is capped at 2.20 ghz why? i have a water cooler so i should be able to handle the thermals
Are you overclocking it in BIOS?
Do you see any of the below LED's lit?
yes i always overclock ion the bios and yes the green circle led is lit but it isnt overclocked right now i reset it back to factory so my pc would run right for now
