Solved Need help my pc starts then shuts down!
Sounds like a heat issue or a psu issue. How old is the pc? When was the last time you cleaned out the inside of your case (dust)?
Please give us your complete pc spec's.including the OS.
@Bruce @phillpower2
I changed my motherboard/cpu/ram Specs: MOBO: Asrock B450 Pro4 CPU: AMD Ryzen 5 2600 GPU: Asus Nvidia Geforce GTX 1070 ti RAM: G.Skill 16GB 2x8GB Ripjaws DDR4 3200MHz PSU: Corsair 650W VS650
G.Skill 16GB (2x8GB), Ripjaws V, DDR4 3200MHz
