Solved Need help in determining the best laptop for upto $1050 budget
maxim123
409
19
Hi, is this a good specs for the price of $1050? Its original price was around $1400 here, saw this in offer recently. I am going to be using it for gaming, maybe some light streaming as well.
Honestly for stuff like you are planning on doing I will always suggest a Desktop system and never a laptop.
Granted they can be used yet they do overheat and cannot always preform the way as advertised.
Reactions: maxim123
Hi, looking for laptop mainly because there are electricity issues here and my inverter battery can support a laptop for longer time, while a pc can't be supported at all.
Look for a reputable brand as well, getting replacement parts for some of these no-name laptops can be impossible.
Everything breaks eventually, doesn't hurt to have options for fixing it.
