Need HELP I fresh restart my PC and now I get 30 or lower FPS
Mattr78
29
Hey , so I fresh restarted my pc because it was being unresponsive and really laggy , checked for virus and malware and nothing was wrong their. After it restarted it been working fine but each game I get on i get about only 20 FPS and it’s looks bad ! Not sure what to do !
specs -
2060 super
I7 9700F
8 core 3.0ghz (4.7 GHz turbo )
16 GB DDR4
2 TB SATA III hard drive
Hey so just found out that I have like 10-15% cpu usage when running games , I’m pretty sure they are supposed to be around 60% plus
What games are you trying to play.
