Solved Need help for my Asus Eee top ET1060c
G.george p
3
20
Hi, i want to replace Hdd with ssd on my asus eee top ET1060c
And i really don't know what ssd's are supported for this specified for this computer i'am really not good at it, please help
I couldn't find any on Google regarding this, so you are going to have to pull off the back cover and see what it already has.
should just be a 2.5" SATA 5400rpm mechanical hard drive.
if so, that would easily be replaced with any 2.5" SSD.
Reactions: G.george p
Thank you very much for your help.
