Need 1TB/2TB hard drive recommendations for my build
Corrupt abyss
3
30
Below is my current PC build...I'm low on storage and need to add a hard drive. I'm looking for either a 1TB or 2TB hard drive depending on the price difference, I haven't decided yet. I need some help picking one out though, thanks.
CPUAMD Ryzen 5 2600 3.4 GHz 6-Core Processor
MotherboardGigabyte B450 AORUS M Micro ATX AM4 Motherboard
RAMG.Skill Aegis 16 GB (2 x 8 GB) DDR4-3200 Memory
StorageCrucial P1 500 GB M.2-2280 NVME Solid State Drive
Graphics/Video Card (GPU)Gigabyte GeForce GTX 1660 Super 6 GB OC Video Card
CasePhanteks Eclipse P400 ATX Mid Tower Case
Power SupplyCorsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply
The biggest question is what is the system going to be used for?
1) 500 GB SSD for OS
2) External USB drives for storage/backups
1-2) internal storage HDD (can be added down the line)
Partial to Samsung drives other may have more suggestions.
Why not use the M.2 for the OS?
Storage
Power Supply
Go with a Gold
