My pc is making a very loud noise and im not sure what's the cause
Have you checked your fans? Also listen to see if your hard drive is making that noise. You will have to open the side panel..
Hello, im currently running a chkdsk command and after its done ill open the side panel and determine if its the fan or the hard drive, will come back after that.
ok im back, the chkdsk didnt give any errors however i booted into bios and set the settings there to default and that seemed to fix the problem
It actually created another problem where the monitor loses signal after a while and the pc then restarts itself
edit: ok i opened up the pc and one of the gpu fans was out of the gpu so i put it back in and things are ok now
