My first build, please advise!!
Heelage
24
Hey, So i play competitive call of duty but it recently moved from console to pc so i gave up and i am now wanting to go at it again. I definitely want a build from a company but obvs i can customise. I spoke with pc specialist and they gave me a build with great power so when the 3 series are available again i can get one and itll work fine. But i ideally want a 3060 ti and i found this build by cyberpower uk. Is it good and will it be great for what i want to do? i have a 1080p 144hz monitor and my budget is nothing ideally above 1.8k. I will put both build down below.
Cyberpower 3060 ti build (£1599)
  • CAS: Corsair 4000D Series Mid-Tower Black Gaming Case (OEM - no fans included)
  • CPU: Intel® Core™ i7-9700KF - 8-Core 3.60GHz, 4.90GHz Turbo - 12MB Cache, Ultimate OC Compatible (No On-board Graphics)
  • CS_FAN: 4x 120mm Cyberpower Addressable Dual Light Loop RGB 1350RPM Fans with Remote Control
  • EXPAN: Built-in USB Ports
  • FAN: Cooler Master Masterliquid Lite 240 Liquid Cooling System w/ 240mm Radiator, Extreme OC Compatible (Cooler Master CPU Water Cooling, Extreme OC Compatible)
  • HOLIDAY1: BullGuard Internet Security for Windows PC with Game Booster! (1 Year / 3 User Licence) [+0]
  • M2SSD: 1TB (1x1TB) WD Blue SN550 M.2 NVMe PCIe SSD - 2400MB/s Read & 1950MB/s Write (Single Drive)
  • MEMORY: 16GB (2x8GB) DDR4/3200mhz Dual Channel Memory (Corsair Vengeance LPX w/Heat Spreader)
  • MOTHERBOARD: MSI Z390-A PRO: ATX w/ RGB, USB 3.1, SATA3, 1x M.2
  • OS: Windows 10 Home (64-bit Edition) Perfect for most people with all the core features of Windows 10 including: automatic updates, Cortana and DirectX 12
  • POWERSUPPLY: Cooler Master MWE 700W 80+ Certified Gaming Power Supply
  • RUSH: Standard Processing Time
  • SOUND: HIGH DEFINITION ON-BOARD AUDIO
  • USB1: Built-in USB Ports [+0]
  • VIDEO: MSI GeForce® RTX 3060 Ti 8GB - Ray Tracing Technology, DX12®, VR Ready, HDMI, DP - 4 Monitor Support (Single Card)
  • WARRANTY: DESKTOP STANDARD WARRANTY: 5 Years' Labour, 2 Years' Parts, 6 Months' Collect and Return plus Life-Time Technical Support
  • WNC: Intel Wireless AX200 Wi-Fi 6 802.11ax Dual Band (2.4 GHz & 5GHz (160Mhz)) PCI-E Adapter & Dual Antennas
PCspecialist 1660 super build (£1558):
Case
CORSAIR 4000D AIRFLOW TEMPERED GLASS GAMING CASE
Processor (CPU)
AMD Ryzen 7 5800X Eight Core CPU (3.8GHz-4.7GHz/36MB CACHE/AM4)
Motherboard
ASUS® TUF X570-PLUS GAMING (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - ARGB Ready!
Memory (RAM)
16GB Corsair VENGEANCE RGB PRO DDR4 3600MHz (2 x 8GB)
Graphics Card
6GB NVIDIA GEFORCE GTX 1660 SUPER - HDMI, DP - GeForce GTX VR Ready!
1st M.2 SSD Drive
500GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6900MB/R, 5000MB/W)
1st M.2 SSD Drive
1TB PCS PCIe M.2 SSD (2000 MB/R, 1100 MB/W)
Power Supply
CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Power Cable
1 x 1 Metre UK Power Cable (Kettle Lead)
Processor Cooling
CoolerMaster MasterLiquid Lite 240 High Performance Liquid Cooler
Thermal Paste
STANDARD THERMAL PASTE FOR SUFFICIENT COOLING
Extra Case Fans
2x 120mm Black Case Fan (configured to extract from rear/roof)
Sound Card
ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)
Network Card
10/100/1000 GIGABIT LAN PORT
Wireless Network Card
WIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
USB/Thunderbolt Options
MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Operating System
NO OPERATING SYSTEM REQUIRED
Operating System Language
United Kingdom - English Language
Windows Recovery Media
NO RECOVERY MEDIA REQUIRED
Office Software
FREE 30 Day Trial of Microsoft 365® (Operating System Required)
Anti-Virus
NO ANTI-VIRUS SOFTWARE
Browser
Microsoft® Edge (Windows 10 Only)
Warranty
3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour)
Delivery
STANDARD INSURED DELIVERY TO UK MAINLAND (MON-FRI)
Build Time
Standard Build - Approximately 15 to 17 working days
Price: £1,588.00 including VAT and Delivery
Flip a coin
I have mainly used intel chips - not for any other reason except that's what was normally supplied.
After working on a couple of different sites I notice a lot of gamers are using Ryzen.
I will ask someone else for an opinion also.
I would probably go for the Ryzen
As for a case, to me a computer case is a black box with bits inside - old school.
Who really has a desktop computer on a desktop where they can watch the lights as opposed to the floor
@Bruce
Reactions: Heelage
I concur - 50/50 either way.
If I was forced, I'd go the Intel also, only because I have never dealt with AMD and when they first came out they had issues, obviously those days are long gone but I've never had a reason to move away from a good thing.
both builds are solid.
both could be improved.
as always, it comes down to money and usage.
Reactions: Heelage
